enrico
ETV300 Olivetti machine (ex Understanding CP/M...)
Let me make some other tests. At this moment a bit after the POST the serial port goes up turning up CTS, DSR and DCD so it works as a DCE (=modem). I connected the com1 of my pc with teraterm and the pc works like a DTE. I not know if the ETV300 waits for a break key or other keys working with a kind of protocol language . So it not answer at the moment.
I know that other machine could load automatically its boot diskette or wait for a key to do this while they can answer for bios commands.
May you take a check on your documentation of other machine of that time or on the typewriter machines to see if and how they could use the pin 9,10,12 and 13 of their serial ports? They are not generally used on standard serial port. so it seems that those pins could be used for other proprietary use.
Enrico
Enrico
