Upgrading M4 to 128k, how?
BartH
Netherlands
I have a M4P and a M4, both are 64k machines. For a special project I need one of them to be 128k, preferably the M4. As far as I know both of them are Non-GA's but I'm not quite sure if this differs, and how to be 100% sure. What is needed to do the upgrade, apart from the 4164 chips?
Bart
If I remember correctly, when I upgraded mine I had to remove the bypass caps next to the RAM IC sockets for the HIGH Bank. Then I had
to remove the Jumper DIP and Insert the PAL at U72.
TRS-IAN is the only source for the programmed PAL U72 that I know of. He frequents this forum and will likely respond.
Larry
As a minor clarification, the Non-Gate Array Model 4P already has the required PAL installed; it is only the Non-Gate Array desktop Model 4 that needs a 'U72' PAL.
Thanks guys for your help! The link to the PDF answers all my questions at once! I'll contact Ian for the chip.
Bart
