andy
I bought an IBM 8514 monitor last week. It's in good condition, but desperately needs some new capacitors. Having no luck getting any of my modern systems to output 1024x768 87 Hz interlaced, I decided to try making an EDID adapter for it. This will allow a modern video card to read the monitor's capabilities over the DDC.
I used Analog Way EDID editor to create the EDID:
https://www.analogway.com/americas/products/software-tools/aw-edid-editor/
I started with the EDID from a "modern" CRT, and removed all the modes the 8514 can't display, and then added the 3 that it can. I also changed a few other minor things like the model number, and programmed it to a 24C02.
I built a quick and dirty VGA pass through from some extra connectors, and soldered a 24C02 to the appropriate pins of the VGA plug.
Windows now displays the correct video modes, including 1024x768 interlaced. Interestingly, it also allows 800x600 interlaced, and the monitor does sync to it. I haven't figure out what it's doing there since the 8514 doesn't support 800x600.
The Windows 7 boot screen is out of sync, but it comes into sync as soon as the desktop appears. I can't judge the picture quality of the 8514 because of the bad capacitors and need for some adjustment.
