Eudimorphodon
Either that, use compression, or replace the internal flash. What else did you expect?![]()
Heh, yeah. Again, I was just being lazy and hoping that maybe someone had already pre-baked a distribution installer that combined compression techniques like those employed in the LiveCD/LiveUSB distributions to give you a "fire-and-forget" installation, but still kept it a "conventional" installation instead of something session-based like Knoppix or Puppy.
I think for laughs I'll see if I can install that Bunsenlabs Debian spin (its funky minimalist UI has been growing on me; on a low-res screen like 1366x768 it's actually pretty handy to be able to use that otherwise pretty useless Search key to launch applications and whatnot) on a compressed btrfs filesystem. If I eliminate dedicated swap a setup like that might leave the better part of eleven gigs open on the internal flash. It's a mild hassle, but... I dunno, I had to fiddle with the oldschool debian installer on the first installation anyway and it pushed the nostalgia buttons.
It's unfortunate that the internal flash is a welded down BGA chip. Some Chromebooks used M2 or MSATA because they're just seriously de-spec-ed Windows laptops, but the N42 is the "real deal". If I have to be honest, though... I kind of love these little x86 SoCs. I know by comparison to a "real" modern PC it's a flyweight, but it's actually kind of amazing that you've got one chip here that crams about the same CPU power as the most powerful dual-core system you could buy in the 2005-ish timeframe plus a video accelerator that's... pretty lame, but has some tricks up its sleeves (video decoding) into four watts of power draw.
