Ok Dave, thanks!Ok. So back to basics...
The first thing is to monitor the stability of the +5V ANA and -5V ANA power supply rails with your oscilloscope to ensure they are nice and stable with no noise on them. If there is any noise on these power supply rails we will never get a good picture.
Dave, the other Vectrex has only ic304...MC34002Ok,
I would suggest putting the diagnostic cartridge into your other Vectrex and scoping the outputs of IC304 and IC306 (pin 6). Note what the picture image looks like and the oscilloscope traces from the two operational amplifiers. Then, compare and contrast the image and oscilloscope traces from the current machine (with the diagnostic cartridge running) - and look for the differences.
I am assuming that both of your Vectrex machines have an IC304 and an IC306.
Yes i can seeWell, I can see some large glitches on both the X and Y traces of post #330 but not on the traces of post #331.
We need to find out where those glitches are coming from.
Do you see the glitches yourself when you view your two videos?
Ok i'll do this tomorrow ! Thanks so much and good eveningCan you scope IC302 (4052B) pin 14 please. This signal is common to both of the final opamps. Again, we are looking for glitches.
Ah ok...no glitches...horizontal line!That’s Ok.
Just because it is 0V doesn’t mean it is incorrect!
The important thing is that there are no ‘glitches’ on it!
Ic305 pin3:Next oscilloscope traces to be taken are on:
IC305 (4066B) pin 3 (Y).
IC305 (4066B) pin 9 (X).
