deramp5113
The Monitor listing will be in a Vector Graphic manual (i.e., not Micropolis). If the listing is present, it will be in the same manual that details all the Monitor commands.
Mike
Mike
Drive select for drive 0 is on connector pin 10. When this asserts, the light on the front of the drive should come on and you should hear the head load (if a floppy is inserted). Check this signal before you boot and verify it's high, then verify the signal goes to ground when you issue the GOTO command to boot. Verify this at the controller end and at the drive end.
MZOS lives!!
