Caluser2000
Banned
Does it beep with no ram?
Sorry I had forgotten about the internal speaker.
I took out the video card and tested it without it and it gave this beep code in the video : https://www.youtube.com/watch?v=annxmNtWKbQ
After reinstalling the card and powering it on again I found it still does these beeps. Do the beeps mean the motherboard isn't dead then?
I couldn't uninstall the RAM to test it without RAM. I've been accustomed to the little clips you pull and they eject themselves out so I'm not entirely sure how to get these out easily.
I just got back from the test and I had used Brasso to clean the contacts (it's not a serious problem is it?). If it matters I always go over the pins with a dry rag multiple times after application.
My results after I reinserted the video card and retested it were that again it no longer beeps at all on startup, so it seems the machine is recognizing the video card. I'm going to take it out and reinsert it again tomorrow. My monitor still doesn't come out of sleep mode when it's hooked up to it though. Does this mean it's likely my monitor is simply incompatible with the card? If not do I still need to uninstall all the RAM for a test tomorrow?
It will probably be a few weeks before I go to storage so I'll update when I test with the old monitor. Today I reseated the video card though and it gave a new beep code shown here : https://www.youtube.com/watch?v=qJovBrYAZXE. I also noticed after I had reseated it that a 2-pin jumper had come off it somewhere on the card.
So that first long drone doesn't count as a long beep? Also, I found where the jumper went so I'll try to take out the ram again and see what happens when I power it on.
I don't hear any long drone unless you're calling the memory tick sound a drone. I hear the two beeps which indicate a memory parity failure.So that first long drone doesn't count as a long beep? Also, I found where the jumper went so I'll try to take out the ram again and see what happens when I power it on.
Taken out the RAM and there are 4 1MB KO-13N sticks and 4 Itausa ICMM4M409 sticks. I can't find online how much memory these sticks are, but they are twice the size of the 1MB so I would guess 2 MB per stick. Means the system would have 12 MB total memory. Will have an update sometime soon.
