reading the schematics and technical manual, it seems like the metal assembly that houses the power plug also houses the AC input filter? if so, i'm getting continuity between the ground prong of the power plug and the exterior of the assembly. would this be a simple repair or should i consider replacing the power supply with the ATX conversion i've been reading about?
edit: also yes, currently in the US
