Early Compupro CPM-80 Master Disks were on SSSD (single-sided single density) 8" floppies. The Boot Tracks on the early versions (up to 2.2N) of CPM-80 were recorded SSSD, and the console ports set at 9600. Step rate and Head Settle times were set for single-sided drives (which have lower/slower performance speeds). Later CPM-80 Master Disks were recorded with the Boot Tracks set for 1024 bytes sectors, even if the rest of the disk was formatted 128, 256, 512, or 1024 byte sections.
The later CPM Master Disks (Versions Q, R, S) were recorded on SSDD (single-sided, double-density) 8" floppies. Boot Tracks are recorded with 1024 byte sections, regardless of how the rest of the disk is formatted, because with time, the Boot or Boot Loader had grown larger than could be fit on single-density Boot Tracks. Console was set for 19.2K baud rate. These Operating Systems assume that you are using DS 8" drives with the faster/higher step rate, and do not work with single-side drives that do not meet double-sided performance specs (step rate, head settle rate).
If you have a later version of Compupro CPM-80, and use single-sided drive, the system will work better, if you switch to double-sided drives, OR borrow a double-sided drive, and reassemble the operating system with the drive parameters set for the slower, single-sided drives.
Do not try mixing the files/utilities from early and later versions of Compupro CPM-80. The utilities are not compatible. Different Versions of CPM-80 had BIOS developed by different authors, and they require/expect the User to use different Assemblers (from different Software Publishers) if altering the unassembled/commented source code is being assembled.
If you have the Console port speed set wrong, when you try to boot the system, you may not get anything on the terminal console. The Compupro System is going to look for Console 0, before it completes booting up. If the Computer is looking for a Console at 9600, and your terminal is set for 19.2K, you may not see anything. If the Computer is looking for a Console at 19.2K, and your teminal is set for 9600, you might see garbage on the terminal.
