cj7hawk
I guess I'm never too old to learn something I never would have thought true had it not been for the source of the information.
www.quora.com
When did Zilog remove the RFSH pin signal, and what did they replace it with? I don't think I've seen a datasheet that had something else there?
A nice change for this pin would have been to make the R register 8 bits instead of 7, but the whole backwards compatibility result would have been problematic.
The 2016 user manual shows it still there, so I'm wondering when it disappeared? ( https://www.zilog.com/docs/z80/um0080.pdf )
David
How did the Z80's automatic DRAM refresh feature improve the reliability and performance of systems compared to other processors of its t...
Answer: Designing the Osborne-1 computer I was able to make use of the “REF” signal from the Z80 to time the video screen refresh. I used a cheap and multiply-sourced LSI counter chip of Motorola design to provide the stream of screen access addresses and avoided the need for an expensive (and th...
David
