Which 8bit Card You Will Recommend ?
nesan
Despite of cost I have a choice of some 8 bit ISA Disk controller card To buy. My need is:
System: 8088
Should be able to run Hard disk and CDROM.
1) ADP50-------IDE
2) ADP50L------SCSI
3) TMC850M
4) TMC850MER
5) TMC-850IBM
6) TMC-850MCD
7) TMC-850MEX
8 ) NEC T128
Like stable operation some 200-300Mb HD enough
I am appreciate your help to assist me.
Thank you
System: 8088
1) ADP50-------IDE
2) ADP50L------SCSI
3) TMC850M
4) TMC850MER
5) TMC-850IBM
6) TMC-850MCD
7) TMC-850MEX
8 ) NEC T128
Thank you
Currently, there is few (if not none) conbtrollers able to do CD-ROM reads for 8088 systems, at least if you got an IDE CD-ROM.
If you are able to wait, I would recomend the XT-IDE board some of the members on this forum are working on. We do plan to add ATAPI (CD-ROM) support, but it will take a lot of time and will then problably be a feature avalible through a firmware update long time after the card itself is released.
But else, I would recomend a SCSI card since most of the IDE ones are way overpriced (seriously, they're not worth $200).
System: 8088
1) ADP50-------IDE
2) ADP50L------SCSI
3) TMC850M
4) TMC850MER
5) TMC-850IBM
6) TMC-850MCD
7) TMC-850MEX
8 ) NEC T128
Thank you
My 8-bit SCSI TMC-840 worked with a 1/2 Gig HD
and 32x Plextor SCSI CDROM
Definitely I will buy at least one from him. It should be encouraged such kind of effort more over it is going to have more feature. I will add my request on this project. No matter How long to wait.:welcome:
Dose it work with IBM and Clone too?
It was inside an IBM PC 5150.
It also worked inside an IBM Luggable 5155.
I can give you the exact models of each part, the card, the drive, the cd-rom if you want.
Yes please. Do you have the BIOS Dump of this Card as well. In case If I receive my card without bios it may be helpful to have one. Did you ever try this card in with IBM colon PC?
Thank you
Thank you
The IBM 5150 has a VGA Card, the 5155 has a IBM CGA Card.
