Basically all monitors support infite number of discrenable shades of any of the beams they use, driver circuit is adapting the signal.
TTL monitors are triggered to set up exact intensity.
I thing the issue in late 70s early 80s was getting some sort of normal DAC on board graphics card. A simple, fixed and non-integrated circuit could be realized for 2 and 4 bit depth, but for more, and true flexibility (palette choice) a real DAC would have to be there. But it was expensive. Easier to create TTL adapter in the monitor itself.
5 years pass by and now the problem is there is no DAC on the board and any extension of gamut requires pins on the video port.
Ofc it's worth mentioning that by increasing transistor count in an average IC over time, multiplexing problems suddenly go away, as it becomes cheap to serialize bitstreams. In about 20 years from digital/analog monitor shenanigans we moved everything to serial approach, both external peripherals and video.
But yes, analog VGA allowed us some very high resolutions meanwhile, just by using a rather simple RAMDAC. Standard lasted good 15-20 years.
