All, I'm using Willem programmer board v5.0 ,but a tad newer refresh. Instead of two 3,5 mm leds on lower left corner I have 3 surface mount leds. Also there are lots of SM chips. Maybe this is relevant, maybe not.
I use B0.992D (DOS) version of the Willem programmer software, as this, my ancient computer and the stupid PCI LPT-port add-on card with AXIS chip, is the only combination I could get the programmer board to be recognised with the programmer software. Win7? No! XP? No! LOL. So DOS it is.
Programmer finds the board and I can set the chip to 27c256, which I have, and I can read chips and verify they're empty. Now the target is to burn a newer Apple Iic ROM to 27c256 chip. Partly that works but only partly. The FF first bytes from the image file are written all over and again to fill the eprom. And naturally this won't work too well.
The image file looks perfectly ok. At 0x100 the actual program code begins. Before that there is bunch of peoples names. File is http://mirrors.apple2.org.za/Apple .../ROM Images/Apple IIc ROM 04 - 341-0445-B.bin
What causes this behaviour and how to correct it? Please note I'm on UTC+2 TZ, so answers may get postponed till next day.
