Wimodem232 and Proterm on Apple//e
Robuck
Philadelphia PA
Hello, I’m trying to connect to bbs boards from my Apple iie using pro term 3.1 and a wimodem232. So far I’ve gotten everything to work for the most part, up to the point where I start issuing AT commands to the modem. My main question is how do I configure the WiFi network of my modem in proterm? I was unable to find anything useful in both the wimodem and proterm user manuals. Hopefully one of you has done this before and can give some guidance.
I'm confused - the Wimodem232 docs are pretty clear on how you set up the device for your wifi network.
What's the issue?
g.
I will tell you after struggling with this for a while, use proterm 2.1 instead (you can download the dsk image from archive.org). I struggled with proterm 3.1 for weeks before I read this exact advice on AppleFritter. proterm2.1 worked for me immediately.
Not sure if this will help, but the baud rate has to be set to 300. I use an Apple IIC and Proterm 3.1. It wouldn't do anything until I changed the baud rate.
