I've got a Western Digital WD1002-27X RLL 8-bit card and a Seagate ST-238R drive that's paired with it for sale.
The only way to guarantee (repeat: guarantee) that you can do 'plug and play' with previously used 'MFM' drives (i.e. connect controller and drive, then watch drive boot, then list existing drive contents) is to use the same make and model of controller that was used before (what is now missing). In some cases, even the same revision of the controller's BIOS ROM may be required.... but this one might have interesting things on it, ...
After the hardware set up, you would low-level format the drive, followed by partitioning, followed by a high-level format.... and I'd like it to be usable if possible.
The only way you'd be able to access the data on that drive is if you ran it with the same controller it was initially used in conjunction with....but this one might have interesting things on it, and I'd like it to be usable if possible.
Since 5150 didn’t come with hard drives, it would be hard to say what card was used when the drive was added, but since it’s an IBM drive there is a good chance it was an ibm card too, I’d guess. Or is there a chance this is actually a 5160?
Where are you located? Maybe someone local could help. I’ve got the later style card mentioned here: http://minuszerodegrees.net/ibm_xebec/ibm_xebec.htm
No, not really... an XT also has an 8088 in it same as the 5150.The machine is a bit unusual in that it's a 5150 but it has a Microsoft Mach 10 "supercharger" card, which gives it an 8086, making it equivalent to an XT, I believe.
Cylinders = 306 / Heads = 8 / SPT = 17 / WPC = 128The HDD is a WD25 IBM HDD, with apparently no information on the drive about its geometry.
According to my notes, it was one of the 20MB drives that IBM optionally supplied in the later model 5160's (together with the third variation of controller shown at [here]).I believe this is the original type of drive that comes with the computer, ...
Well, for the BIOS on an AT motherboard.... and might be considered "type 13" for the BIOS.
