Wyse Winterm VIA EPIA 5000 password problem
Ruud
Heerlen, NL
I received this VIA EPIA but it had the wrong time and MSD mentioned that two floppy drives would be present (none were). So I rebooted the computer to enter the setup only to be greeted by "Enter password:". So I followed the procedure to clear the CMOS but to no good, still got this message. Worse, date and time were gone so when I rebooted, I had to press F1 or DEL every time. I started to write this message when I thought about the old IBM ATs which needed a program, SETUP.COM, to set the RTC. I tried it, nothing to loose IMHO, and it worked! No floppies and date and time are correct now.
But I still have to enter a password. If nothing can stop a program to update some parts of the RTC, is there a way to remove this password protection using a program?
Thank you in advance for any info!
<baffled> Thank you very much, that worked! </baffled> Standard password for this board?
It would appear so. I found it on the BIOS tab on the page you linked to. A quick google search for "password Fireport" confirmed it.
Out of curiosity, what kind of box did your motherboard come in? (Or did you not buy the whole terminal, just the motherboard?) I think this is the same board, or very close to it, that's in my machine that *looks* like it's the same case as a Wyse WinTerm WT3455XL, but has *no* labels on it at all. (I think they just slapped stickers on a tiny OEM case with this one.) It's kind of nifty that I was able to stuff a laptop CD-ROM drive into it using an apropos cable adapter.
I'm given a lot of things and sort it out later. It came w/o HDD and I added the IDE cable and the CF card holder.
As you can see, no labels either.
Yeah, that's pretty much the same, at least the metalwork. (The plastic bezel on mine is squarer, I think? I guess I'd have to pull it out to be sure, haven't messed with it for a long while.) There's no fan directly on your CPU cooler, does yours have the low-power EDEN CPU or is it a regular C7 and they went with a big heat sink and a fan screwed to the case wall? I nearly melted mine because it had a smaller heat sink with no fan on it... but it turned out it was *supposed* to have a fan on it, it'd gone missing before I scavenged it. I'd naturally assumed it was the fanless Eden variant, but then it was crashing every three minutes after warming up and I put 2+2 together...
