Ok "don't shoot me now" ( yet ) I know I should first try all this with a real CBM before to get to any conclusions.
But just a few questions/doubts/things to know.
Yesterday I built this :
I used 4K7 resistors and 2N3904G transistors, despite they say 'it may or it may not work' I cannot see reasons why not (*) as this transistor even when used like switching is rated for quite some MHz
The cable I made out from that is this one :
However I have some doubts like :
1) how can a thing like that work unless somewhere ( in the drive ? ) there are some pull up resistors ?
2) should I test levels with connector inserted in the disk ?
3) getting confused a bit about this, is this the cable that should work 'with any system/sw' or should I swap some clock/data line ?
I am trying to use opencbm, I first installed the 'drivers' but when I try some stuff like :
cbmctrl reset
It takes a couple of seconds and then 'nothing happens'
when I try
cbmctrl detect
it seems to hang .. ( until I disconnect the parallel cable )
"Something" seems to happen/be active because normally I can see only the power green led on the 1541 disk but the moment I insert the parallel cable I hear like a motor spinning and the red led going on.
Maybe something is wrong in the cable I am using ?
Anything I could use as 'test' ? I tried the XCDETECT.EXE but all seems to hang.
Thanks in advance for help.
[edit] - checked and rechecked, the cable seems correct .. mah ..
cbmctrl reset
when I try
cbmctrl detect
