Wawavoun
Hi All,
I am facing a strange xmodem problem.
On one side I have a vintage 68008 board with a 16C750 which is working well for serial console to Linux Minicom.
The 16C750 is interfaced with a MAX232 so I use a serial db9 to usb adapter.
The board run SK*DOS 68K with the TMODEM program.
I have already used this combination on other computer with a different serial port and till now this has ever well worked.
Sending files from the board to the pc everything is ok. Minicom get the file smoothly.
In the reverse direction (pc to board) the transfer wont start.
I run tmodem on the board which go then in a waiting position (he say "he say you have then second") then I run xmodem send on Minicom and everything stay like that till I start to got time out message from Minicom.
If anybody has a good idea how to debug the problem ? Please not I have no access to tmodem source code...
Thanks.
Philippe
Thanks.
Philippe
