Hugo Holden
One very interesting thing is to look at the way a 110/220V switched option SMPS was implemented in the 5155 computer.
It also answers an interesting question, which could perhaps be posed in an electronics exam question:
How can you run the 110V primary of a small line fed power transformer from 220V, without using a dropper resistor, series capacitor or a step down transformer ?...might leave a few exam candidates stumped might it not ?
How about doing it with a bridge rectifier and two large value capacitors and creating a virtual mid point rail from the 220V supply ?
This is exactly what IBM (or at least the Zenith contractors) did with the dual voltage IBM5155 supply. I took a little time in the article to explain how they did it:
http://worldphaco.com/uploads/The_IBM_5155_POWER_SUPPLY.pdf
Once these principles are understood, it easy to convert SMPS supplies to dual voltage.
