XT-CF-Lite v4 Problem
TomL_12953
Malone, NY
I'm using an XT-CF-Lite v4 on an original IBM PC (5150). I discovered that running IBM BASICA would cause a total disruption of access to the CF card until a reboot.
I then flashed the card with the latest BIOS and now the CF card isn't detected at all! I use the Auto adjust settings and all parameters look reasonable.
Can anyone help? I've tried all the settings I can think of!
In possibly unrelated news....I notice a silk-screened marking for R5, a 10k resistor, that has no resistor soldered in. Is that an optional part? The board seemed to work fine before I reflashed (other than the BASICA problem, of course).
Tom L
This happens because the XTIDE Universal BIOS is set to use "Lite mode". You can change it to use "Full mode" instead. See the manual for more info.
That's a bug in the beta3 available for download on Google, which, by the way, isn't the latest version. The latest version is available somewhere at http://www.lo-tech.co.uk but I can't give you a direct link as it seems to be down currently.
Hi Tom. I thought this query was closed already - sorry about that. The site should be back up now :)
Thanks. That much I knew. That's why I was trying to reflash the BIOS.
I don't see a download area there but I'll keep looking. I'm currently trying to use 2.0 B3.
Tom L
Linux system update broke it... now sorted.
It's up again but I must be thick. The only link I could find there brought me right back to Google Code where the latest version is 2.0 B3 (the one I already have).
Sounds like a hardware problem. Make sure the RAM is OK and/or try another CF card?
Problem: I can not copy or write to my CF card with my new bought XT-CF-Lite v4 . CF is fdisked and installed on a Glitch XTIDE: no problem. I tried 4 days to make the CF card work. I flashed 5 versions of the BIOS, and made sure all addresses are correct and tried out. The CF card boots in the XT-CF-Lite v4 , and i can read the DOS directory. BUT I CAN NOT WRITE TO IT. I guess one of the components on the XT-CF-Lite v4 is out. Could it be th EEPROM? Tx for any input. Joseph.
To be complete: the Glitch card and a 16 GB CF, 2 GB partitioned, DOS 4.1 works flawless in my IBM 5150 and 5155. The XT-CF-Lite v4 card can boot with this CF card, and I can read the directory, but I can not copy or delete files to this directory. I can not fdisk the CF via the Lite card. The cursor just hangs. HELP.
