glitch
The holes in the PCB are sized for a press fit with the header strips provided. This is so they don't fall out when you turn the board over to solder it. Every now and then, a board gets a little more solder in the through-holes than it should have, and the headers can be a bit difficult to insert. I just rock them back and forth. The "snap" of them going in is the slightly deformed tip of the pin making its way through (they get deformed from the pin-cutting process, when the headers are manufactured).
