modem7
10k Member
'Dead' gives the wrong impression. A floppy drive will be drawing power even when not connected to a controller.But without a motherboard the floppies just lay dead. They don't seek until they are initialized, and even then not without the aid of a FDD controller.
Different drives will draw different amounts of power, and different switch-mode power supplies will have different requirements as to start-up loading.
In fact, part of my 'Minimum Diagnostic Configuration' procedure (specifically the page [here]) for the IBM 5150 relies on the fact that a single Tandon TM100 floppy drive is known to present enough of a start-up load for the IBM 63 watt power supply.
It is aways going to be a case-by-case thing.
Well, they will add additional loading, but there is still the chance that the total start-up load will not be enough for your particular power supply.I was thinking two floppies might add additional loading in case the hard drive alone wasn't enough.
It is just something to keep in the back of your mind.
