I am unable to update my chips to RC2 from RC1, the utility keeps reporting the EEPROM keeps timing out, i can force the issue by manually using the flasher, or telling it to add a wait-state while writing, but if i do that, it stops just short of detecting the hard drive, or the XT reports that the ROM is bad. This has been tried on all the chips, one got bricked, the others wont take new code. only 1 of them took the new code and works ok, it was flashed using the defaults, same as the others. What could be causing this. I have even tried the recovery method earlier in this thread, no luck there either
*update*
I was able to manually update 1 of the bad chips using the /A parameter of the flash program, but it keeps saying verify failed, 2 columns are shown the left has different values than the right ones. I'm guessing these chips are simply refusing to take the code, no matter what jumper settings i feed it.
**update** it reports unexpected byte where another should be and fails, with the write enable jumper, ON of OFF it's ignoring the jumper. I am beginning to wonder if i have found a bug in the card
