OrangeJacketGuy
Some time has passed since I last posted in December 2022. [here]
Life can often get in the way of things and getting my AT&T PC 6300 was naturally a lower priority. Some years passed and I never truly got back to getting my Olivetti M24 clone until the most random of things happened. I was going to the Reuseum last month to get a few resistors and misc items (btw, this is a place you should visit when in the Boise area). Upon approaching the storefront, I saw the unmistakeable backside of an M24. I thought my brain was playing tricks on me but sure enough, when I got in there it was in fact what I've been pining for. I was kinda pressed for time so I didn't check it out at that point. I was kicking myself for not picking it up, and a few days later I came back and got it, without even really inspecting the machine.
Rushing home with it, I DID remember to immediately remove the RIFA cap and the battery. Being that far into the power supply, I saw that it was merely dusty but otherwise ok. I grabbed a semifuncitonal IDE drive to act as a load for the 12v and 5v lines. The rest of the machine passed visual inspection. There was an MFM controller card in there, but no drive or even the rails for floppy drives.
I knew it was going to be a while even under best conditions and some luck to get any video out of it, but I plugged it in anyways and I heard the rather distinctive beep that I hadn't directly heard in decades. For an unrelated project I had a Tandon TM 100-2A, and I hooked it up just to see what would happen. I'm 99% sure that the motherboard was getting so far as to attempt to read from floppy, which means that a bunch of other things are also likely working. Yes, I understand that I'm very lucky in that regard.
I hadn't bothered reading up on the clock situation until now. I didn't know that the battery situation is basically pointless to fix, given that it's apparently not even Y1992 compliant. I've been watching a lot of Tibo's Youtube channel again just to refresh myself on the road ahead.
I'm probably going to put the MFM controller on eBay since currently it doesn't look to be directly useful to me. It is an SMS/OMTI Model 5520 REV D. I'm also arguing with myself on whether just to power through using the original display hardware and an RGBtoHDMI with a little bit of custom cabling, or to somehow get an 8-bit ISA VGA card. Both are going to be a bit of effort. Perhaps someone can settle the debate?
There's also the looming issue of the keyboard. I really don't want to get an Olivetti keyboard as I don't have good memories of them. I am aware of a post from years ago about a possible alternative but we'll see what happens.
If I start getting anywhere with necessary hardware I still might do videos on it.
Thanks again for your time.
