Hello all,
I want to install 4 half-height drives in my PC XT clone case. 2x 5.25 inch 360KB drives, 1x HDD 5.25 inch and 1x 1.44MB 3.5 inch drive inside a 5.25 inch bracket)
I have already 2 drives installed with that loose side plate. I added this plate when the drives where in. ( i know you need some kind of plate to connector 2 half height drives make it as a full height one)
Its getting harder when installing those last 2 drives.
The third drive isnt still a problem when installing it on the bottom ( i know where all screw holes are) (also those on the bottom)
I can copy (making new one out of metal sheet) the loose side plate which i already have.
Only how going i install it when the 2 drives are all ready in? Also the bezel of the drives cant go through the front of the case. (front the back to the front installation.)
What i can do with an ST-296N drive is trying to remove the bezel (which can) ( i dont know if this option will work for every situation?) Attach that loose plate to the HDD. Insert it from the back to the front. Stick the drive out in the front.. Attach the bezel back to the drive and done?
So the fouth drive insert as a single unit?
Or are there an easier way?
