Accessing System 7 files
Fallingwater
I have a Powerbook 145b I'm using for writing. Unfortunately it has a dead hard drive, so I'm booting off a system floppy I managed to install TeachText on (no, using the super-expensive flash card interface is not an option). There is nothing on the floppy but the system and the text editor, but even that leaves me with only about 80kb free for my text files. Wondering whether there was some way to further pare down the system I tried looking for the MacOS files, but I don't know how to handle them.
Opening the floppy in HFV Explorer there's a "system files" directory which contains a "system" file and a "finder" file. They get copied to Windows as a 852kb "system.bin" and a 293kb "finder.bin". What do I do with these? Can they be opened and tinkered with?
Is there any way of slimming down either of them? I'm thinking since this is a universal System7 disk it must contain various drivers for systems different than my Powerbook, and since I don't need them I could perhaps delete them and gain back some much-needed space.
I do not have access to any other Apple computers, new or old, but I can run Linux if needed.
I found a "screen saver" floppy that had the sole purpose of booting system 7.5 and then running a screensaver. I deleted everything that wasn't the system from it, and I ended up having a few more kilobytes free compared to a completely empty network access disk.
Again, though, both this and the network access disk must have drivers on it that I don't need, no?
If you're using System 7.5, you should try using System 7.0.1 instead. System 7.5 is pretty bloated and slow, especially for a machine with only 2-8 MB of RAM.
You can use ResEdit to further slim down the system briefcase, but you have to be very careful about what resources you're deleting to avoid making it not work entirely. The system briefcase contains fonts, sounds, drivers, icons, etc. that can be carefully selectively deleted but I don't think much space can be saved.
Another option would be to use a null modem cable between the PB 145b and a PC:
http://www.ccadams.org/se/serial.html
You could transfer files back and forth with a terminal program.
Can't you eject the bootup floppy and put in a blank data floppy and swap disks as needed?
Edit: If System 7.5 works like 6 and below in floppy only cases, putting TeachText on the data floppy would reduce the number of disk swaps.
Have you considered converting these writings to a more accessible format and continuing on from there? Why beat your head against a wall? :-)
Yes. If you can get it booting and doing what you need with extensions off (hold down SHIFT as it boots), then you can dispense with the extensions and control panel folders entirely. As others have cautioned, I'd be very careful about deleting resources out of the System file. The NA disk is pretty tight already.
No, it will ask you to insert the system disk as soon as you press any of the mouse buttons (no joke!)
System 7 simply wasn't made to rum from floppy disk. At least not when having only a single one.
The 145b only supports 7.1 through 7.6.1, and I was unable to find a barebones bootable 7.1 floppy with more available disk space than the aforementioned "screensaver" floppy with 7.5 on it. I'd be glad to try if someone can tell me where I can find a 7.1 bootable floppy and if I can get TeachText to run on it.
Thanks, I'll look into this.
Nope. I tried, and it immediately complains and tells me to reinsert it. I guess 4MB of RAM isn't enough to run the system from.
They already are in an accessible format. Can't get any more accessible than .txt.
As for the hardware itself: I have three modern multi-core computers, at least eight older single-core desktops ranging from a 5x86 to a Thunderbird 1.4, so many laptops from the last decade and a half that I can't be arsed counting them, five netbooks, a Nec 900C, an Alphasmart Dana, a Palm IIIx with the foldable keyboard, a Toshiba NC100 and a constantly increasing number of tablets and bluetooth keyboards ("hey, I've decided to upgrade from this tablet because it doesn't run Lollipop, do you want it or should I throw it out?"). Trust me: if I wanted something else to type on, I'd be typing on something else.
I just like the 145b's feel, its keyboard and its massive trackball. I actually built a custom lithium-ion battery for it so I can use it around.
It does boot with the extensions off and TeachText runs, but the extensions and control panel folders are already empty in the disk I'm using. Would it make any difference if I deleted them altogether? I'm assuming not, but I don't yet have a full grasp of old Mac filesystems.
Sounds like you're screwed.
I hope your head and the wall are friends. :-)
Lowendmac said the 145b could run 7.0.1, they must be incorrect. You've probably already tried 7.0.1 if you say it won't work.
