TheRealAnubis
- Joined
- Jan 16, 2022
- Messages
- 32
Hi - I always take a pic before I do the work, and I replaced all the caps on the board, including the RIFAs. I've checked the polarity against the original picture, and also the schematics, and they're in as they were originally.I am trying to open the pdfs in this file but they are showing up corrupt. Did you try and open this?
edit: website crashed when making an edit./ I will have to remember what I typed... So I dont like cap kits.. They usually have no instructions and they dont cover all the caps. Its up to the seller to pick and choose what they add.. Cap kits are like a "tune-up" on a car. For the most part the term is make believe. A tune up can be wiper blades and a new alternator belt. Its just easier to source the caps you need yourself.. ITs easy, your smart enough to have written things down so you are more than capable.
Again a blown rifa wont take out the psu... at all. The problem with your board (have worked on a bunch of them) is there is no silk screen. so I am assuming your board was still working when you got into it and made changes. Did you take photos? Without photos and no silkscreen you could have easily reversed a cap polarity. I highly recommend you re-trace your steps. Maybe even undo the changes. However if you dont have photos on polarity.. dont bother that might just get you more lost. We need a schematic to verify the cap polarity. Can you at least make a dot with a marker on each cap you replaced so it will be easier to check?
I just opened the .7z file and all the files inside opened fine. I could also try to attach the files here:
