qbarnes
New release of gw2dmk: https://github.com/qbarnes/gw2dmk/releases/tag/v0.0.1.alpha.8. Please report any problems found.
- On MS Windows, when Greaseweazle was on a COM device with 2 numbers (e.g. "COM57") and running on an old version of the OS, gw2dmk wasn't using the "\\.\" prefix hack so had to specify the device name with the prefix as a workaround. Update should make this prefix unnecessary.
- Plugged some memory leaks.
- Command fails now if "-d <drive number>" is not provided on the command line instead of defaulting to 0. Will autodetect drive number soon.
- Incompatible sides check (--[no]compat) wasn't detecting properly.
- Crashed when writing out DMKs to HD floppies.
- All kinds of drives (-k option with 1 to 4) should now be fully supported. Before only -k 1 was supported (1.2MB HD drive writing to single and double density diskettes.
