1950s oscilloscope restoration (help needed)
Drayson
Oklahoma
Hello everyone, I just received a 1950s WO-33A oscilloscope, and my goal is to restore this thing to working condition. However, I'm not exactly sure where to start.
IMG_3643.jpegIMG_3644.jpegIMG_3645.jpegIMG_3646.jpegIMG_3647.jpegIMG_3648.jpegIMG_3649.jpeg
I don't intend on reselling it or anything, this is just meant to be a fun educational project for me, as well as something extremely old to have in my collection.
If anyone has any tips on dealing with ancient tech like this, I'd gladly appreciate it. Thanks in advance!
That's a nice little scope. I've got a Heathkit IO-12 a bit bigger than this and an old WW2 British Air MinIstry scope that's about this size.
It's been damp. The first thing you want to check is the transformer for shorted and open windings. The high voltage for this CRT is around 1KV, and the transformer winding is rather delicate. First check it with an ohms meter and then isolate it and give it some power and vheck the voltages.
The main filiment winding will be 6 volts, and another filiment winding for the 6x5.
There will be a B+ windings with a centertap to chassis ground. From groundmI'd guess at about 350 volts at each leg of the B winding. One side of the B transformer then goes further into the high voltage leg. There should be somewhere around 900 to 1500 volts for a 3" tube. Most likely close to 1000v
Outside of the transformer being dead the rest of it will be easy to work on. Spray the controls down with WD-40 and let it soak in.
All the capacitors need to be changed. They're all the same stuff we're using in antique Radios and TV's. They might cost about $20 to change. There's likely some carbon resistors that are drifted as well.
Be careful when probing around 1KV is not plesant to come in contact and you will dance. Watch around the intensity and focus control terminals as this is part of the high voltage circuit.
Thanks for sharing your experience and insights, syntax error!
First should check the transformer, remove the rectifier (or all) tubes or desolder the rectifier diodes if any there. There should not be power to the filter capacitor, or it may blow off. Then put a 50-100W 115V filament type bulb instead of mains fuse, it will act as a fuse if there is short... leave it working that way for few hours. In my experience there is 50/50% chance for rusty transformer to short after a while.
Good point Milen about dim bulbing it. That poor thing looks like it's been under water. It wouldn't hurt to bake it for weeks on end in a trunk of a car in the heat of the summer or somewhere else cooking hot.
