1MB (1024KB) L2 CACHE DIMM for PowerMac 6100 wanted
dr.zeissler
Germany
Hi there I found out that changing the L2 Cache from 256KB to 1024KB will make a huge performance boost on my powermac 6100/66.
Obviously there will ony be third party modules available while apple never produced such big l2-cache dimms.
I would love to buy a 1024KB Dimm L2 Cache for my PM6100.
Payment will be paypal, location is germany.
Thank you very much for helping me out.
References/more information:
http://www.micromac.com/products/l2ca256k-6100.html
http://www.kan.org/6100/l2cache.html
https://web.archive.org/web/20011006172735/http://www.mindspring.com/~l2co/WhatIsCa.html
If your dos compatibility card is in the right angle PDS riser, there are G3 upgrades which replace the riser board and still have a PDS slot so you can use PDS cards.
Now I know what you mean, but I don't understand the manual:
http://www.sonnettech.com/support/downloads/manuals/crescendo_nubus_manual.pdf
The Dos-Compatible is not mentioned as "compatible" and the manual only says:
Remove PDS Card
Locate the PDS slot (Figure 3) located next to the ROM card. If there is a PDS card already installed (such as the 6100 DOS card), remove it.
There is no talking about putting it back in after upgrading with the G3. I understand this as, Dos-Card not usable after upgrading.
Am i wrong here?
From the diagram, it looks like the G3 upgrade card has a right angle PDS slot on it, meaning a PDS card can still be plugged into the G3 upgrade. But I guess for whatever reason, the DOS card doesn't play nice with the G3 upgrade.
