Hey Mike-
I appreciate your suggestions, but you really can be quite snarky.
Guilty as charged; I think that when you ask strangers to spend considerable time helping you with a problem then it would be helpful to answer any questions they ask to help them reach a diagnosis, and it's a little rude to just ignore them.
On top of vague and confusing references to 'rails' as opposed to specific pins/points, "SRAM" instead of IC numbers etc., EEPROMs vs. EPROMs, 75154s vs. 74154 etc., so far pretty well all my questions have gone unanswered:
- What are the ROM numbers and where are they (not relevant in your opinion, and not relevant any more now).
- Do you have a scope or a friend with one?
- Was there a pattern to the 'static' character (whatever that means) and if all the same, what is it?
- Where is C77 on the schematic (not on the board)
- What's the resistance between UD7 pins 21&24 and 12 with/without a ROM? What range/polarity are you using?
- How and where did you measure 'continuity' between the Vcc and Vss rails
with power on?
I don't enjoy having to ask the same questions several times so I don't care any longer, but perhaps someone else may find an answer or two useful.
Perhaps you failed to read my response in post #27 with a follow up in #29. You must have missed the "No continuity between the two rails" where I begin to find this odd capacitance behavior and then #30 where I discover that these rails are shorted when the board is energized.
I didn't see anything relevant in post 27 and I'm curious how you measured 'continuity' with the power on. In any case, as Giobbi also points out above, talking about 'continuity' between 'rails' is not at all the same as measuring the resistance between two pins of a specified IC, as I asked and
you are asking
him to do.
I'm sure that you are much smarter than me, though, so please tell me...
(sarcasm?)
Have you ever seen that be anything other than something acting as a capacitor?
Anything whose resistance is related to heat, for example... Sizzling would certainly suggest something heating up and it should be pretty simple to find where this excessive current is being drawn, presumably somewhere around UD7.
I'll leave you in more capable and patient hands, and sincerely wish you luck.
