3032 not stable screen
emilen72
Terni, Italy
Hi to all, I'm new here...
I have got a faulty 3032 with the classic screen garbage at the power-on... after reading the forum, I have test the voltage (but these are good) and changed however all the caps on the mainboard but nothing to do... garbage still remain after change the caps...
After this I have looked at the ROM...
I have built ad ROM adapter form my willem PCB3B programmer and with it I have discovered that one rom, basic 2 - 01, was faulty...
I'have write the code on a new 2732 and putted in the socket... power-on and.... wow... the pet it still lives!!!
bua a little trouble remain!!!
the screen in not rock-solid... all on the display move little bit, right-to-left in slow and continuous way. seems all it waves.
If look the screen from one meter it seems stable... but if I approach myself 10 centimeters to the monitor, this phenomenon note a lot…
any ideas where put my attention for fix this? have you need some other infos?
many thanks in advance to all
