SomeGuy
Anyone have this issue with ibm branded software? I'm seeing rings on some discs. I'm trying to figure out if the drive in my new acqire PCJr is wrecking disks.
Although this disk didn't have any rings and I tried it in my 5150 which I never have disk issues with and it never touched the jr. (Well not for 20 years at least). But it seems like every disk I put in the jr winds up like this. I have tried cleaning the drives with a diskette.
I think the jr wrecked a PC booter disk it came with. Anyone know how to back them up?
Never test a drive with an original disk.
Your drive heads are probably physically damaged. Remove the disk drive and visually inspect the heads. A cleaning disk won't fix physical damage.
As for copying disks, it looks to late for this one. Normally just copy disks with the DOS "diskcopy" command. For copy protected disks use Copy II PC or Google for an "unprotect".
If this happens to have been a normal disk, then you can try diskcopy using a known good drive and keep mashing "retry" when an error comes up. If this was copy protected you are pretty much out of luck as a copier won't know if the damage is part of the "protection" or not. And off hand I don't see "Home Budget, Jr" posted anywhere.
