IndirectX9
Hello again, VCF!
Now the Dell 4400 might not be classified as vintage yet, but I need some help configuring a 2 floppy system, 1 drive being the 1.2 megabyte Epson sd600 5.25 floppy drive (jumper on DS 2), and the standard floppy drive (DS 1 by default?). I used a universal 5.25 card edge connector cable w/ 3.5 ports and 34 pin mother board connector, and when I removed the terminator and set the jumper to DS 2, both drive lights would be on, and if I were to put a disk in either drive, the motors will be spinning. I tried configuring the 5.25 drive in the BIOS but it only showed 1 diskette drive as being detected, (which was the 3.5). So after switching the connector to use the twisted end on the 3.5 floppy drive, the same thing occurs, both drive lights are on and do not respond to DOS commands, so only after removing the 3.5 inch connector, I kept it on the 5.25 drive and it appeared to work, but still wont respond to DOS command ( I believe it is because of the drive jumper and the terminator). How can I use both drives with the system? Is it Possible to use both drives?
Note: The OS is Windows 98 SE
Note 2: The BIOS DOES have support for 5.25 inch floppy drives, it is the configuration that I'm having issues with
Thank you.
-IndirectX9
Thank you.
-IndirectX9
