If you think you know 5150's, then let's see if you can give the correct answer to this problem.
"Early level 5150 machines may not work properly with the color graphics adapter installed. The color monitor will not display color but will display black and white. The problem may occur with system boards P/N8529205 or P/N8529299.
If color cannot be achieved by adjusting the color potentiometer on the system board as per the Hardware Maintenance and Service Manual..."
Now, who can complete the solution? If you don't know, you'll likely never guess. I never would have.
Joel
Joel
