clh333
I acquired one of these printers in a package with a 5160 XT years ago and have been searching for replacement ribbons ever since. The OEM IBM ribbons fit but are all dry by now; the replacements, beside being cheaper and flimsier, never seemed to fit.
Cutting to the chase: The replacements - all that I've ever run across - have a hole in the middle of the drive gear that is supposed to mate with a gear in the printer but the hole is 10% smaller than the OEM. The ribbon cart is supposed to fit on a post next to the drive gear and secure contact with the printer drive. The smaller hole (6mm vs. 6.6mm) won't allow good contact so the ribbon doesn't advance and the printhead strikes the same spot on the ribbon with each pass.
A 5/16 or 3/8 drill bit will clear the way. Use vice-grip pliers to secure the take-up knob (on the top side) while you drill as the clockwise turn of the bit is the reverse of the ribbon wind. With the cart installed, once you have made good contact, gear to gear, you shouldn't be able to move the knob by hand.
-CH-
-CH-
