Stone
10k Member
Can somebody explain why the DOM runs fine even when not connected to the PSU? It not only runs fine but the machine also boots from it normally. Does it actually use that 5V for anything?
DOMs don't connect via a cable, at least not natively....pin 20 is the keypin, which means it may or may not exist, it may or may not be blocked off on the cable...
Ya', that's what I meant by 'not natively'.You can get male 40-pin IDC connectors for ribbon cables, I use them all the time for DOM refits where the DOM has to share an IDE channel with something else (CD-ROM, Zip drive, whatever).
