Acorn A4000 out of scan range
alexis234
Hi. I turned on my Acorn Archimedes A4000 and on the monitor it said "Out of scan range." Then I turned it off, on again and it worked. Then the next day I tried it and it always says "Out of scan range" and won't work at all no matter what I try. Any tips on what could be wrong with it?
Probably your RTC battery is dead. There are some key combinations by which you can select VGA or RGB monitor output:
If it's a VGA monitor, hold down the 3 key on the numpad (not the main keyboard) until after the beep.
If it's a "TV" (RGB) type monitor, hold down the 0 key instead.
