ajcc
A small update, somewhat on topic
Haven't spent that much time with the SUNs, I've mostly been going between work and sleep. Today I had some free time and went and got myself a storage shelf. Took it home on the bus (should get a drivers license, this is getting stupid) and moved the computers into it.
Here's the first test fitting as many computers onto the shelf as I could:
Probably will move them around a bit. But hopefully having them always setup and ready will give me time to work on them I have an old Pentium MMX machine stuck full with I/O cards that I'll use as the terminal box for all the machines, once I get that box going again. Have to solder up some more null-modem cables as well, lots of work as usual.
On the top is an old DEC StorageWork SCSI raid, thinking about hooking it to the Indy or Ultra1, haven't decided yet. There's also a stack of SUN SCSI cabinets not in use or in the shelf. Hopefully I have enough disk Most of the machines are running NetBSD, haven't decided if I like the project or OS yet, it was quite the fight getting it all setup. There's no CD-drives for the SUNs or the Indy.
So that's a little update.
