hjalfi
I've just acquired a Tandy CGP-115, mint in the box, one of those ubiquitous four-color ALPS plotters which are so fiendishly unreliable. Mine doesn't work, of course, otherwise I wouldn't be here, but mine has failed in an interestingly different way.
The two miniature nylon gears which always break are, on mine, intact. There are two things faulty on mine: firstly the little plastic lever which connects the pen solenoid to the bar which pushes the pens against the paper had snapped. I managed to fix that by fusing the pieces together with a soldering iron, but while I was working on that the paper feed stepper motor slowly stopped working. It's not the gear, which is still intact, but the shaft no longer rotates.
So, this sounds like it's either the driver electronics (big chunky through-hole transistors, easy to replace) or the motor itself, which looks much less easy to replace. Or something else I haven't thought of. Does this look at all familiar to anyone?
