SunDown79
So i have started work on a newly acquired Altos 886 system and have cleaned out a lot of dust as much as I thought was needed.
Its looking a lot better inside already now and perhaps not 100% its ok for now.
Next thing I cleaned, included the heads, was the floppy drive but that seems to have died. It damaged a test floppy I put in it so I am marking the drive as a write-off for now.
Now I was wondering if I could use a HXC floppy emulator, probably I suppose but has anyone done that ?
And second related question, does anyone have images for a 886 from which it can boot or even better from which I can install the system ?
Third question about floppies, what format does it use ? 80 track I am guessing but does it use 256bytes/16 sectors like some of the more exotic things that ran on 5xx systems if I am correct or does it use standard 512bytes/9 sectors ?
Grts, Stefan.
Grts, Stefan.
