VERAULT
- Joined
- Jan 30, 2012
- Messages
- 9,977
I would return the machine as well. Did you download the Compaq Softpaq bios floppy and set the correct parameters in the bios?
I have a portable II. I bought it from a junk seller on ebay.. I should have returned it.. IT is a terribly finicky beast. The power supply is a nightmare. Im not sure if yours has the same configuration mine did but it came with a winchester hard drive controller (mfm) and a compaq daughterboard to convert it to early IDE . The drive was a 20mb ide and mine too was dead. I was able to get a 127mb 2.5" old lapter hard drive to work in it (using only 109MB, but good enough) there are alot of things that could go wrong with what you are explaining.
