Does anyone have any ideas on how to fix the errors on the hard disk on my Amiga 3000, so that I can copy as much as I can off of it?
I've spent the last 3 days dealing with SCSI issues on both my A3000's. The one with the Cyberstorm was my main machine for a while and has registered version of YAM, Miami, Aweb II and Shapeshifter on it, as well as things such as Adoom. The other is a stock A3000 that the previous owner had hacked for a Video Toaster. Both still have the original custom chips. Neither will allow me to hook a second drive up to the built-in SCSI bus. This is why I stopped using them. Both have 40.68 ROMs installed.
On the Toaster machine, I had previously put a new install of 3.1 on it. I took the Toaster out and put an A2091 (6.6 rome and 04 SCSI chip) in it's place and hooked an older NEC CD-ROM to it and the machine was then quite happy to install 3.9 off of CD, with no SCSI errors or lockups. In fact the speed was quite good.
On the 68060 upgraded machine, due to the checksum errors on the hard disk, I've not made any progress whatsoever. Disksalv in repair mode booted off a floppy, even crashes the machine at random points. Since the A2091 worked so well in the other, I plan on upgrading it's ROMs and SCSI chip and using it to mount a second hard disk so that I can save what I can off of this machine. Thankfully the data partition seems to be fine currently.
Any suggestions would be greatly appreciated.
Thanks
