cosam
I was tinkering with the old A500 last weekend when it suddenly stopped reading disks. When it tries to boot, it just flicks the heads back and forth three times, then gives up. I dug out an A1200 floppy to try in it last night. It doesn't fit in the case, but seemed to get a bit further: The Workbench screen came up, but then it also had trouble reading the disk. Now booting from the A1200 floppy does exactly the same as the old drive.
I found a schematic and tried swapping the CIA chips - no change. Got a scope on the various floppy signals and they look reasonable, to my untrained eye. Drive select, motor and index pulses are all coming through great. What I'm not sure about, however, is the actual data signal coming from the floppy (pin 30). I'm not sure what to expect, but it just looks like a steady voltage with a very feint analogue signal trying to get through. I thought maybe the chip connected to this pin was pulling it high, but it looks the same even with that pin lifted. I have an external floppy too, but I'm reluctant to try it as it looks like the machine has somehow toasted two drives already.
I wondered about alignment, so tried booting from hard disk and formatting a floppy. No joy there either - it failed whilst verifying the first cylinder. It looks like it can write OK but has trouble reading back.
I'm kinda out of ideas now as to what to try next.
