Tincanalley
Definitely a new skill. I think I need to apply it to a PS/2 drive. It is from a model 50Z I've had since new in '88. It stopped reading and writing properly. I started by cleaning the heads, but that didn't help. I then read about the capacitors needing to be replaced. I did that, but not with surface mounts. My skill in soldering is decent, but not for SMD. So I went about finding the smallest radial caps and using those. All went well, but the drive still has the same problem. I figured that if I messed up replacing one or more of the caps, I'd have a worse problem. So it has to be an alignment or head problem. With the track pitch so much tighter than the Tandon, I'm not sure if IMD will be of much help.Good work! I did something similar trying to allign a teac 55gfr a few nights ago. You live and you learn. Upside at least you learned something new.
