MicrocomputerSolutions
- Joined
- Jul 30, 2012
- Messages
- 563
I just got back from picking up the stuff that was advertised as a Garage Cleanout/Recycling Bin Save. I can believe it took all day. Was supposed to be a quick out in back. Planned on 90 minute drive over, 60 minutes there, and 90 minute drive back. 4 hours total. Left the house at like 9:30am, and got back just before 6:00pm, after stopping for a late lunch. Heavy traffic, and bad directions from MapQuest did it. 90 minutes to unpack the car and find a place to stack it in the house. And now, it's 8:30pm.
Planned on looking for 8" floppy drives to overhaul and use for parts for my business, and came home with much more than I planned. I don't have the space to store a lot of this stuff, so it's sitting in the front entrance in my home.
The following stuff is available inexpensively (or some stuff is give away if you show up in person to look and can use it).
I do not recognize the manufacturer of the Mainframes and power supplies. All of these were made by the same company. They are commercial made production units, I just don't know who made them. I have not plugged any of these units in (yet) to see whether the power supplies are any good. The price will be lower if I don't do any work on them.
(1) Mainframe with drive bays for (2) vertical 8" full height floppy drives. Drives are mounted on the right(I have never seen this before), and 6-slot card cage with vertical card slots in on the left (when looking fro/at the front). Ventilation fan on rear with metal mesh filter. Fuseholder built into power socket. (2) ac power jacks in rear. Plenty of RS-232 punchouts, plus punchouts for 50-pin drive cable and centronics parallel port. Power supply for S-100 boards plus floppy drives. Includes cover/top.
(1) Mainframe with drive bays for (2) vertical 8" full height floppy drives. Drives are mounted on the right, and factory 6-slot card cage with vertical card slots has been replaced with a 12-slot card cage whuch hilds the board horizontal. I think I saw a CCS (California Computer Systems) trademark on the motherboard. 12-slot card cage is lighter gauge/thinner metal that the rest of the box, and while well-made, might be a homemade part. Mounted to the left of the drives when looking from/at the front. Ventilation fan on rear with metal mesh filter. Fuseholder built into power socket. (2) ac power jacks in rear. Plenty of RS-232 punchouts, (16?) plus punchouts for 50-pin drive cable and centronics parallel port. Power supply for S-100 boards plus floppy drives. Includes cover/top.
(1) Mainframe with drive bays for (2) vertical 8" full height floppy drives. Drives are mounted on the right, and factory 6-slot card cage. THIS IS AN INCOMPLETE MAINFRAME WITH SHEETMETAL ONLY. NO MOTHERBOARD, NO POWER SUPPLY, NO FRONT PANEL, AND NO COVER. Includes mounting plate (with three full wave rectifiers mounted) for power supply and mounting plate for floppy drives. Nothing on the rear panel except for punchouts. Holes for ventilation fan, fuseholder, (2) ac power jacks, plenty of RS-232 punchouts, (16?) plus punchouts for 50-pin drive cable and centronics parallel port. Same sheetmetal as 6-slot mainframe described above.
(1) Mainframe with 22-slot cardcage. 18-slot motherboard is marked Vector Electronics. Vector Electronics licensed to built some of the older Compupro designed boards and even used the same circuit board manufacturer that Compupro used. The only difference between Vector Electronics licensed Compupro board, and Compupro boards is the silkscreened company name and location on the boards. Appears to be a Compupro motherboard, has a Compupro style power connector, but as far as I know, Compupro never sold a 18-slot motherboard. I believe that Compupro used the #155 model number on 12-slot motherboards Non-IEEE components. Silkscreen is in white, Compupro (this is the earlier Non-IEEE 20-slot motherboard) has used yellow for silkscreen markings for as long as I have known. Card cage with normal side to side board positioning inside case. Ventilation fan on rear with metal mesh filter. Fuseholder built into power socket. (2) ac power jacks in rear. Plenty of RS-232 punchouts (12), plus punchouts for 50-pin drive cable and Centronics parallel port. Power supply for S-100. Includes cover/top.
(1) Mainframe with 22-slot cardcage, (NO MOTHERBOARD), card cage with normal side to side board positioning inside of case. No ventilation fan on rear, No fuseholder built into power socket. No ac power jacks (holes for (2) in rear. Plenty of RS-232 punchouts (12), plus punchouts for 50-pin drive cable and Centronics parallel port. Plate for power supply is included (three full wave rectifiers mounted). Includes a unpainted cover/top. Same sheetmetal as complete mainframe described above.
(1) Drive Enclosure top/cover. Nothing else. Appears to be from a Lobo OR JMR drive cabinet/enclosure. Very thin gauge metal. Not sure which as there are any markings. Anybody need a lid? If not, it's going into the recycling bin.
Got a few S-100 boards that I won't sell through my regular business, as they are not Compupro boards. Jade Z-80 CPU board, what might be a Jade floppy controller board, some Tanner 64K Static Ram Boards, and a brand new Tanner BARE BOARD Static 64K Ram Board.
If any of this sounds interesting to you, let me know and I can email you some photos of the item/s you are interested in. Figure out what you are willing to pay, and PM me.
Acceptable price will be lower if you are picking up, and I am not looking for a box big enough to fit and enough packing peanuts to fill the box up.
