The Apple //c was manufactured by Apple Computer, Inc. from April 1984 to August 1988. It was the fourth in the Apple II line, and it was Apple Computer's first attempt to create a portable computer system. The IIc was the first system to use Apple's Snow White Design scheme, which was used in later Apple computers such as the Macintosh.
The Apple //c had improvements over the Apple IIe, such as:
- The new CMOS-based 65c02 processor
- Twenty-seven new processor opcodes
- Fixes to the IIe ROM that allowed Applesoft BASIC to work with lowercase characters and an 80-column display
- Mousetext display characters that allowed the creation of graphical user interfaces from text
The Apple //c had no expansion slots, which was a drawback. However, it had most popular cards built-in, including an Extended 80 Column Card, two Apple Super Serial Cards, a Mouse Card, and a floppy drive controller card. It also had a built-in 5.25" floppy disk drive, a new feature in the Apple II line.
Technical specifications (from Wikipedia
- Microprocessor
- 1.023 MHz 65c02
- 8-bit data bus
- Memory
- 128 KB RAM built-in
- 32 KB ROM built-in (16 KB in Rev0)
- Expandable from 128 KB to 1 MB (Rev1 and later, or with 3rd party expansion board)
- Video
- 40 an 80 Columns text, 24 lines
- Low-Resolution: 40 x 48 (15 colors)
- High-Res: 280 x 192 (6 colors)
- Double Low-Res: 80 x 48 (15 colors)
- Double High-Res: 560 x 192 (15 colors)
- Audio
- Built-in speaker, 1-bit toggling
- User adjustable volume (manual dial control)
- Built-in storage
- Slim-line internal 5.25" floppy drive (140 KB, single-sided)
- Internal connectors
- Memory Expansion Card connector
- Specialized chip controllers
- IWM (Integrated Wozniak Machine) for floppy drives
- Dual 6551 ACIA chips for serial I/O
- External connectors
- Joystick/Mouse (DE-9)
- Printer, serial-1 (DIN-5)
- Modem, serial-2 (DIN-5)
- Video Expansion Port (D-15)
- Floppy drive SmartPort (D-19)
- 12-Volt DC connector input (DIN-7, male)
- NTSC composite video output (RCA connector)
- Audio-out
