David_M
I have three Apple clone boards that lack the ROM card they need to operate. They are the type of board that has a 16k RAM card and Z80 included on the motherboard and due to a lack of motherboard space used a modified slot 0 designed to accept a custom ROM card. The cards were typically populated with a 2764 in socket 1 and a 2732 in socket 2. Sometimes they used 2732's in sockets 1 through 3. Socket 0 was never populated because the select lines don't go anywhere.
Because my boards are essentially useless without the cards I plan to have some made. I can get 10 made with a HASL finish at minimal cost but if there is enough interest from others that need them I will consider getting them made with a gold plated edge connector.
To be clear these will not work in real Apples of any kind or in a clone other than the type with a built in Z80 CPU and 64K onboard.
