Hello
I have an Apple II M&R Enterprises Sup'R'Terminal 80 col card for the Apple II. Wasn’t working but by replacing the ram and associated IC’s it now works. However, unlike the Apple II itself I do not get a signal from the composite output that displays on my LCD screen. I have to go through a Scart/Composite to HDMI box to get a display (a scan doubler also works). I find this strange as the Apple II composite output is fine and so is a Microtek Magnum 80-col board. My LCD handles both PAL and NTSC signals.
the rom has 50hz written on it and it works fine. I tried a 60hz rom image found on the net and same thing.
The link to the only available documentation for this board is
http://mirrors.apple2.org.za/Apple%2...7R%27TERMINAL/
My question, How does this board generate/set the frequency of the composite signal ?
I am trying to figure out if this behaviour is normal or I still have a problem.
thanks
Andy
thanks
Andy
