EagleTG
Hi all.
I've taken on a project to restore a handful of Apple II disks. Around 50 or so of them.
The owner of the disks and I are interested only in the data on the disks, to that end I'm currently using ADTPro to restore on a known-good drive.
The original disks have some mold issues that I've been contending with. I've made good progress on this front with lots of drive head cleanings, and some work in cleaning the disk "cookie" itself including transplanting the "cookie" to a donor disk sleeve. This part I've got pretty well figured-out. I'm probably in the neighborhood of 32 of the disks where I've been able to get some form of a "good read" off of them (where data shows up in the images either via mounting in an emulator or viewing with a hex editor).
What I'm struggling with is the format of the disks themselves. A lot of them are simply unknown. Original labels (if they exist) on the disks just say things like "88-89", and we have no idea what was on the disk. I've found that some of the disks show a catalog of contents from ProDOS. Some boot in an emulator when attempted, some don't. I've also noticed that some of them won't image properly even if the original disks I'm working with are copies themselves. I had suspected copy protection, but I guess I'm not 100% sure.
For each disk, I've made two images, one using the regular copy mode of ADTPro, one with the nibbler mode. This gives a bit greater success, usually if a disk doesn't work in one format, it will work in the other format. Is this the recommended approach?
Most of it appears to be word processing data. The disks seem to be widely written via a program called PFSWrite, I've had some issues with testing my recovered images but I'm wondering if I'm just not using PFSWrite correctly. Some also appear to be written via AppleWorks.
My thoughts are a bit scattered on this project, but I guess my main question is, what is the "best" way to archive these to get the greatest chance of the images being usable? I'm a bit of a newbie when it comes to Apple disk formats, and I'm beginning to understand that it was really the "wild west" with Apple disk formats back then, there were really no standards. What is the best approach to image these disks, with some chance that they might work the first time (as I'm especially concerned that some of these will be damaged to the point where I might only have one or two chances to read them).
I've considered using 4am's Passport, as I think that seems to detect certain aspects of the disk image better. My issue there is that software is geared more toward copy protected disks of which most of these are not.
Also, I'd appreciate pointers on how to convert this data to a newer format. I've seen some success with using CiderPress, and have been able to get some of the disks working via emulation (as mentioned above). Any other tips on converting to newer standards? For most of this, I'd probably be happy with some sort of text format.
Additionally, what is the preferred Apple II forum out there? I see some communication on the Apple sections of AtariAge and here, but due to the amount of activity in the Apple community, I'd expect to see more posts out there. Especially judging from the frequency of posts on some of the Apple Facebook groups. My Google-fu is failing me on this front.
Thanks again for any pointers that you can provide!
Edit: I forgot to mention, I understand that the PFS:Write program was written in Pascal, and that the resulting disks were in the Apple Pascal disk format. I have read that this complicates things as many copy programs can't understand this format. I have a strong suspicion that this is a lot of what I'm running into and am unsure how to get past.
